Machine learning
Ente supports on-device machine learning. This allows you to use the latest advances in AI in a privacy preserving manner.
You can search for your photos by the Faces of the people in them. Ente will show you all the faces in a photo, and will also try to group similar faces together to create clusters of people so that you can give them names, and quickly find all photos with a given person in them.
You can search for your photos by typing natural language descriptions of them. For example, you can search for "night", "by the seaside", or "the red motorcycle next to a fountain". Within the app, this ability is referred to as Magic search.
You can enable face recognition and magic search in the app's preferences on either the mobile app or the desktop app.
On mobile, this is available under General > Advanced > Machine learning
On desktop, this is available under Preferences > Machine learning
The app needs to download your original photos to index them. This is faster over WiFi. Indexing is also faster on your computer as compared to your mobile device.
TIP
If you have a large library on Ente, we recommend enabling this feature on the desktop app first, because it can index your existing photos faster. Once your existing photos have been indexed, then you can use either. The mobile app is fast enough to index new photos as they are being backed up.
Also, it is beneficial to enable machine learning before importing your photos, as this allows the Ente app to index your files as they are getting uploaded instead of needing to download them again.
The indexes are synced across all your devices automatically using the same end-to-end encrypted security that we use for syncing your photos.
Note that the desktop app does not currently support modifying the face groupings, that is only supported by the mobile app.
For more information on how to use Machine Learning for face recognition please check out the FAQ.
